Can I use an oil pump from dr650 on the xf650?
Verfasst: 7. Jun 2014, 16:43
von SLOXF650
Can someone help me with information if the oil pump for suzuki dr650 will fit on suzuki xf650 without problem?
Ive heard that the engine of dr650 is the same as the engine of xf650 is this true?
thnx for help!
Re: Can I use an oil pump from dr650 on the xf650?
Verfasst: 7. Jun 2014, 18:05
This is true for the DR 650 SE models (SP46). All the engine parts below the cylinder head can be swapped from a XF to a SP46 and vice versa.
All other DR models don't have anything in common with neither DR SE nor XF.
Best regards,
