Moin
Lange her hier. Aber welche Teile kann ich alle rausschmeißen. Benzinhahn braucht keinen Unterdruck mehr bei meiner XF
Gruß Mike
						Unterdrucksystem rauswerfen
Re: Unterdrucksystem rauswerfen
How did you connect the vacuum port of the carb to the fuel petcock? the diameters are not the same, which means you had to keep the t splitter and plug the other end of it?
Did you leave the hose between the air cleaner port and the carbs connected instead of plugging them?
