Hello,
when I pusch the starter button, it makes noise like slip and then the engine run with the starter.
Which is the problem?
Starter is breaking or only to tight the clutch?
Is like a slipping of clutch.
Starter run, slipp, engine start.
When is cold is more. When is warm, slipping is less.
Do you konw how to inspect starter clutch? In the service manual is not clear how to dis-assemble
...same problem at me. Just remove the starter (from the right side of the bike), clean and grease it. Only 2 screws, but you have to demount the exhaust manifold and the cam chain tensioner (be sure you know how to mount/clamp it!!).
