Chain kit (need some advice)
Verfasst: 28. Aug 2008, 16:59
von Xandros
Hello ! Bref: i want to change the rear sprocket with a 41 teeth one (from Suzuki DR 650). Freewind has the rear sprocket with 43 teeth which puts it in higher revs than the DR. Example:
Freewind - 110 km/h at 5000 revs in the 5th gear
DR 65 - 110 km /h at 4000 revs in the 5th gear
Have any of you done anything like this ? Please, help !
Alex
Verfasst: 29. Aug 2008, 00:52
http://www.xf650.de/forum3/viewtopic.ph ... ce3ee#8909
What kind of help do you need?
What is your question???
Verfasst: 31. Aug 2008, 20:30
von Xandros
Well ... DR 650 has the rear sprocket with 41 teeth and XF with 43 teeth.
I want to know if i can use a chain kit of DR for my XF and what would be the result .. ?
Thank you !
Sorry, i saw now that you`ve done that ... my question is: you`ve replaced only the rear sprocket or the chain as well ? (DR 650 chain ?)
Did you feel a lack of power doing this ? Less acceleration ?
Verfasst: 2. Sep 2008, 22:26
As far as i know, the chain of DR 650 SE and XF650 are equal.
So you can use a chainkit of the DR as well!
Do you think you can feel a difference of 5% acceleration? I can´t!
Verfasst: 2. Sep 2008, 23:09
Brummbär hat geschrieben:Do you think you can feel a difference of 5% acceleration? I can´t!
That's true. I went 5% to the other side (shorter) and it is barely noticable.
Should've changed it by 10%.
cu,
