Unterdrucksystem rauswerfen
Rillguzzi
Re: Unterdrucksystem rauswerfen
Beitrag von Rillguzzi »
Moin
Lange her hier. Aber welche Teile kann ich alle rausschmeißen. Benzinhahn braucht keinen Unterdruck mehr bei meiner XF
Gruß Mike
ronenfe
Beitrag von ronenfe »
How did you connect the vacuum port of the carb to the fuel petcock? the diameters are not the same, which means you had to keep the t splitter and plug the other end of it?
Did you leave the hose between the air cleaner port and the carbs connected instead of plugging them?
